Lock Global Change
Anbin Ponnith
User offline. Last seen 8 years 34 weeks ago. Offline
Dear All,
How to hide my global change commands from the usage of others.Is there any option in p3 to hide certain tabs and commands from the usage of others.
With Thanks & Regards,
Anbin Ponnith
Jose Frade
User offline. Last seen 3 years 36 weeks ago. Offline
HI,
U have to create the users that can access your project database (in NetSet) giving the necessary rights in P3.
Be sure that only you have the right "read/write". It will be required to change the right to user "everyone" from read/write to read only.
To all the users you want to prevent from having complete access give access "restricted". Then go into the restrictions button and define which things he/she will be allowed to do. There is a lot more options then Global changes.
This rights remain property of the database no matter where you store your project
Shah. HB
User offline. Last seen 47 weeks 5 days ago. Offline
In the network connected systems the client will have an access option he can enable the respective function to his members at any moment
Anbin Ponnith
Thanks for the reply,
If the access for many functions such as Global change,filters...etc are denied how to get access once again.
With Thanks & Regards,,
Anbin Ponnith
Shah. HB
It is possible in a system connected in network ,where you could block them using access option i am not sure about stand alone system
