changing Activity ID using global change
7 replies [Last post]
Abdelmoneim Youss...
User offline. Last seen 9 years 36 weeks ago. Offline
how can i change Activity ID using global change
Edgar Ariete
User offline. Last seen 6 years 32 weeks ago. Offline
Hi Abdel,
Now I realized that the Pyramid is very complicated...
Sen Moc
User offline. Last seen 19 years 19 weeks ago. Offline
all the activities ID begin with ،°CM،± and in each activity with it own activity code named ،°MAJC،± (Major Code). Please use global change function to replace activity ID with first character ،°C،± and follow with the major code and serial number. Use the global change function to replace them.
The answer what،¯s the global change function that you wrote
Philip Jonker
User offline. Last seen 16 years 23 weeks ago. Offline
Hi this is simple, create a code cale TEMP with a length of 10, and export this to a dbf file, then insert the new ID’s in this field and import. Thereafter do a global change
Raja Izat Raja Ib...
User offline. Last seen 13 years 50 weeks ago. Offline
Yes edgar,
u callin me, thanks for your introduction, i dont have tips for U, this month.
Hi abdeel,
U can refer to previous Post Thread... in Primavera Project planner - P3> renumbering activity ID
Steven Oliver
User offline. Last seen 12 years 25 weeks ago. Offline
Be extremely careful when changing activity id’s!
Using Global change, from memory, the syntax is something like
actid="A"&actid (to insert an "A" as a prefix)
You may need to run the trim function as well.
If you can be more descriptive of your problem, perhaps better advice can be given.
Edgar Ariete
If you don’t mind waiting...? I’ll just call Raja...(he got the answer I suppose).
cheers
