Regarding the File extension in the P3 folder.
Anbin Ponnith
User offline. Last seen 8 years 36 weeks ago. Offline
Dear All,
What does the following file extension implies,
AC2, ACC, ACT, AUD, CAL,DIR, DST, HOL, ITM, LAY, LOG, PLT, PPA, REL, REP, RES, RLB, SPR, STR, STW, TIM, TTL, WBS, S50.
What will happen If I delete any of these files from the folder.
I just know that If we delete RLB file the resource dictionary will be deleted completely.
What does the other file means,
With Thanks & Regards,
Anbin Ponnith
Kieran Thomson
User offline. Last seen 11 years 37 weeks ago. Offline
So maybe you discufer a way to manipulate data quicker?
Shah. HB
User offline. Last seen 50 weeks 9 hours ago. Offline
Quite interesting ,where they have been used i mean in global change ?
Anbin Ponnith
Thanks a lot,
Anbin Ponnith
A D
User offline. Last seen 4 years 2 weeks ago. Offline
I hope, this is what u r looking for:
ACT Activities Table
REL Relationships Table
LOG Log records Table
WBS Assignments Table
SRT Current sort Table
AIT Read Only Activity custom data items Table
RES Resource assignments Table
STR WBS Structure Table
ACC Cost Accounts Table
RLB Resource dictionary Table
RIT Read Only Resource custom data items Table
DTL Read Only Activity code titles/values Table
HOL Holiday file Table
TTL Title descriptions
DIR General project information Table
SPR Resource cost/spread table
ITM Data in dictionary records
CAL Calendar definition file
REP Resource earned value
AC2 Restricted access records
LAY Project layouts
STW Communicates with SureTrak program
