How to Delete a set of resources for a particular block
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Hi Rob,
when you select and remove will this not remove the resources from the other activities, it is ok if we have allocated these resources to the only block we want to remove, what if the same resources is also assigned to other set of block of activities....
never tried it but this is my querry
cheers
Waz
Hi to all
Check this one works or not
Go to Tools select Global change
Add a new filter
Set the following formula 1 in {Change option}
If RES EQ Planner
Then RES EQ DELETE
Use use Selection option to select particular WBS to delete resource of your choice
OR
Set the following formula 2 in {Change option}
If RES EQ Planner
Then RES EQ " "
I hope it works
Shahul
hi rob
are you talking about p6 or p3?
Select the block of activities with the resources you want to remove.
On the right hand side of the screen click on the Assign Resources Button.
In the new pop window, click on the resource you want to remove.
Now Click on the remove button (Its the one with a red x)
That should do it!
Now Click on the remove butten (Its the one with a red x)
That should do it!
Dear Sir,
I tried with global change also with Import export.But its not deleting all the resources from the activities at a streach.
Anbin
Anbin,
use the global change and delete the resources
cheeers
waz
