How to delete some resources from Resource Dictionary?
Pranab Kumar Deb
User offline. Last seen 3 years 32 weeks ago. Offline
Hello All,
Is there a way of deleting some resources from the resource Dictionary.
regards
Deb
Pranab Kumar Deb
Hello Ronald and Dieter,
That will actually delete the resource assignment to the activities and not the resource from the resource dictionary.
Deb
Dieter Wambach
User offline. Last seen 7 years 38 weeks ago. Offline
Hi Deb
Then it’s Ronald’s way.
Ronald Romero
User offline. Last seen 1 year 22 weeks ago. Offline
Kumar,
You can do it by global change , just filter select all the resource that you want to delete and blank it using this code RES EQ " "
Pranab Kumar Deb
Dear Dieter,
Thanks for the info actually i had to delete a lot of resource so i wanted to know if there is some easier way
of doing it at once and not manually one by one.
regards
deb
Dieter Wambach
Hi Deb
Data --> resources --> you’ll see a table with all resources --> select - one by one - the resources to be deleted --> "-" will delete the selected resource.
