long activity description
7 replies [Last post]
faik ulku
User offline. Last seen 15 years 16 weeks ago. Offline
how can i enlarge the quantitiy of the letters for activity description. for example i would like to write a description which has hundred letters.
thanks
Safak Vural
User offline. Last seen 4 years 15 weeks ago. Offline
Sen sagol. Basarilar.
faik ulku
Tesekkur Safak Kardesim. Ellerine saglik
Safak Vural
Dear Faik,
You can add 2 or 3 custom data items as RUS1 and RUS2. Every item will give you 20 characters to add. If you want to show in reports you can show in layout view or in other reports. It will be easy for you just to import the descriptions.
EX:
RUSS1-FLOOR RUSS2-BLOCK RUSS3-WORKTYPE (depends on your WBS)
Safak
faik ulku
Dear Safak
The problem is we have to present our schedules in both languages in Russian and English. I use log for russian part but log is also not enough for russian translation. that is the problem.
Safak Vural
Dear Faik,
If you can divide the description in parts in a logical way, then you can add a activity code for the un-fit parts of the description and then you can show on the bar chart view as the columns next to activity description. Or you can add Logs to the activities.
Safak
faik ulku
thank you Alex. It is strange.
Alex Wong
User offline. Last seen 11 years 27 weeks ago. Offline
Groups: TILOS
In P3 .... quick answer is No you cannot
In P6 .... put your description in the notebook
HTH
ALex
