Schedule with different Calendar ID
Jun Gallardo
User offline. Last seen 9 years 22 weeks ago. Offline
Hello Planners,
I am working with a schedule with three calendar ID’s (6-days, 7-days and 5-days). In the summarization setting, P3 asks for calendar ID to use, what shall I use? Shall I use the the calendar ID which is assigned the most? (in this case, 6-day). Shall I be getting an accurate summary for the Percent Complete if P3 uses only one calendar id?
Please help. Regards.
Jun
Jun Gallardo
Mr. Iimos,
Thank you for your comment. So, using different calendar ID in a schedule (one schedule with 2 or more calendar ID’s assigned to several activities)should not be recommended?
Anoon Iimos
User offline. Last seen 3 years 26 weeks ago. Offline
I supposed you’ll be getting different results as well. A result for each calendar used.
