Error 429, ActiveX Can’t Create Object
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
That error normally means that a certain active x control is not registered. The most common control to give this error is the microsoft common controls.
This means the only way to fix this problem is to manually register the control using the regsvr32 command.
Please let me know if you need more detail.
