Printing to Acrobat PDF
21 replies [Last post]
Mal Leadbetter
User offline. Last seen 10 years 45 weeks ago. Offline
Groups: TILOS
I am trying to print P3 programmes to PDF
Set up the printer etc, go to print and get error message
Printer Error : General Error
I am sure this has been discussed here before, but I can’t remember the work round
Thanks in advance
Mal
Frederic Fasquelle
User offline. Last seen 1 year 22 weeks ago. Offline
James,
I can’t remind but do you have possibility to modify settings and thus graphic print quality, in order to increase it to 1200dpi for example,
James Barnes
User offline. Last seen 1 year 16 weeks ago. Offline
I have not had this problem with PDF creator, it works fine for me and I just use it on the default settings (at least I think I do...)
Frederic Fasquelle
Hi ASHRAF,
I confirm your asumption on PDF creator, it caused me a lot of trouble in the past.
What you should try is to only print the page distorted and to incorporate them in your master pdf file.
Ashraf Jahangeer
User offline. Last seen 8 years 19 weeks ago. Offline
Hi Mirna,
I have tried this it works but the fonts are distorted.
That is the reson I am using PDF Creator.
Ashraf
Mirna Halabi
User offline. Last seen 12 years 26 weeks ago. Offline
Go to your printer settings, set Adobe PDF Printer as your default printer, go to your program, edit whatever you want in page setup. Then close and click the printer icon in the main page.
This should work!
Dieter Wambach
User offline. Last seen 7 years 13 weeks ago. Offline
I just had the same message. Simple reason: It is a new pc and I forgot to install SP2. So I installed SP3 - the recent one - PDF-printout works fine.
Alexander Bernardo
User offline. Last seen 11 years 7 weeks ago. Offline
Find this adobe software "adobe distiller 5", install it to your computer and it works fine. I’ve been using this for more than a year and i did not encounter problem.
A D
User offline. Last seen 3 years 36 weeks ago. Offline
Never faced this kind of problem!!
Gets converted in few seconds
Tuaha Mustafeez
User offline. Last seen 16 years 40 weeks ago. Offline
hi everybody,
am new on the plannet. Can anybody tell me why primavera takes a longer time to convert the files to Pdf. is this because of RAM of your system or am i the only one facing the problem? plz respond
regards
John Wishart
User offline. Last seen 11 years 26 weeks ago. Offline
Just click on the print icon instead of using the file/print commands, this work for me.
James Barnes
I use the same software as Ashraf and it works fine. We have Adobe writer available here but it was too much of a faf for direct from P3 printing. No problems printing from preview either.
I do still use Adobe Acrobat to bind different prints together to make a full presentation though.
Ashraf Jahangeer
Hi there,
I was faced with the same problem and installed PDF creator and it works perfect.
http://www.pdfforge.org/products/pdfcreator/
Ashraf
Daniel Limson
User offline. Last seen 4 years 52 weeks ago. Offline
Yes, Paul is absolutely right. P3 is an old software running on 16 bit and is no longer compatible with the latest softwares running on 32 bits.
Another solution is to download cute.pdf from the internet and this works perfectly with P3.
Daniel
Paul Harris
User offline. Last seen 1 year 17 weeks ago. Offline
Mal
P3 is 16 bit and cannot handle the long paths used by 32 bit software. Load P3 Service Pack 3 and then go into Acrobat properties and create a new port with a short path e.g C:\P3\OUT.
Then it will work OK, just set the default printer before you start printing.
Paul E Harris
www.eh.com.au
Mal Leadbetter
Groups: TILOS
Funny enough, mine is a Dell lap top to, never had the problem with Toshiba’s. However, I can you PDF for everything else, Word, Excel, MS Project, PowerProject. It just would not work with P3 when in printing from print preview.
Clive Randall
User offline. Last seen 16 years 31 weeks ago. Offline
Ihave a Dell computer and it will never print from anything except the icon
It seems to be some sort of interface problem maybe your hardware is the same
Mal Leadbetter
Groups: TILOS
Thanks all for your input.
Not printing from print preview has worked
Se de Leon
User offline. Last seen 2 years 49 weeks ago. Offline
Don’t use pull down menu i.e. pull down file menu then click print command. Instead, click the print icon only.
Hope this helps.
Se
Melecio Bandibas,...
User offline. Last seen 34 weeks 3 days ago. Offline
Add printer - Adobe PDF and make as default printer.
Go to P3 printer set-up and select Adobe PDF. Go to P3 & click save toolbar.
Click printer tool bar of P3.
Paul Harris
If you have Acrobat then load SP4 and create a local printer port in Acrobat properties with a short path.
Paul E Harris
www.eh.com.au
Ferdinand U.
User offline. Last seen 6 years 46 weeks ago. Offline
Try printing at bar chart view using print icon, not in print preview..I think..
