How to print A0, A1 In PDF???
11 replies [Last post]
Pranab Kumar Deb
Dear All,
Please advise me how can i print in Adobe , pages of size - A0 and A1
regards
deb
Amit Parmar (PMP)
User offline. Last seen 12 years 33 weeks ago. Offline
I use BullZip PDF printer and while printing i can choose the page size.
Amit Parmar
Check out my blog on Primavera at http://www.primaverablog.in
Jhorbam Baena Orozco
User offline. Last seen 3 years 22 weeks ago. Offline
Well i use ABBYY PDF Transformer 2.0 to make my own PDF's Files and this program let me select the size of the paper.
Abdul Rehman
User offline. Last seen 14 years 12 weeks ago. Offline
Hello,
You cannot print A1 or A0 sizes by using PDF Printer, PDF Printer is used for converting any file to PDF file / format. So, First, you have to convert the page in to pdf format (Even it is in A4 or A3 size), and then try to print this pdf file in Plotter. When you choose the printer as Plotter, then click printing preferences. There you have to change the paper size, then you check the print preview..  If it is ok, then click print button...
Thanks.
ABDUL REHMAN
Johnny Xu
User offline. Last seen 14 years 14 weeks ago. Offline
There is noticeably a bundle to learn about this. I assume you made sure good points in features also. Levitra ballooner Viagra insolvencies Cialis Byway
Pranab Kumar Deb
hello Amreshwar and Raviraj , for your great advice,
regards
deb
A D
User offline. Last seen 4 years 26 weeks ago. Offline
Can try this also.
http://www.freeware995.com/bin/ps2pdf995.exe
Raviraj A Bhedase
Ponnaganti Sridhar
User offline. Last seen 8 years 43 weeks ago. Offline
Hai!
Amreshwar Shukla
Thankyou for the address of such a usefull site address i was also searching for infromation on the same subject
Tankyou
Sridhar
Amreshwar Shukla
User offline. Last seen 2 years 9 weeks ago. Offline
Dear Deb,
Download the free software cutepdf from "http://www.cutepdf.com/Products/CutePDF/writer.asp". It is free for personal and commercial use.
Then go to - Start-Setting-Printers & Fax- Then right click the cute pdf writer-properties-Device setting - Chose the paper size of your desire.
A D
which PDF printer u r using by the way?
Pranab Kumar Deb
Hello Raviraj,
In paper size i cannot seee ISO A01 or any dimension more than A3 , please advice
regards
deb
A D
Hi pranab,
Select the PDF printer you have.
In the paper size, select the ISO A0 / ISO A1 size.
(You don’t have A0/A1, but you have ISO A01/A01)
And then just print it off.
Raviraj A Bhedase
