P3 freezes when printing in pdf with logo
Jaime Linchangco
User offline. Last seen 15 years 48 weeks ago. Offline
Hi Fellow Planners,
Good day! I have this persistent problem that occurs everytime i printed a pdf with logo.P3 freezed and pdf file was partially completed.
Is there anyone encountered the same problem and found the solution?
Jaime
Abdul Rehman
User offline. Last seen 14 years 4 days ago. Offline
Hi Jaime,
I think this will help to solve your problem....
If you want P3 Report in PDF Format, first set the PDF Printer (Any type... either Cute PDF or PDF995) as default printer. Then make page setup in which paper size you want to convert (A4/A3/B0/B1).  Then go back to P3 Main window. Then click print button directly (not from the file menu ==> print==> choose pdf printer) from the main  window.
In this way, you won't get any freeze while printing in P3..
Thanks.
ABDUL REHMAN
Jaime Linchangco
Hi Guys,
Problem solved.
For Hannes, it doesnt matter whether you use 1200 or 144 dpi. It all works.
For Ronald, Service Pack 3 partially solved the pdf printing problem, particularly the long directory name or filename.
For Scott, if you have service pack 3 installed, you could just do step 7, "Printing start after last page is spooled".
Thanks Mates!
Cheers!
Jaime
Scott Hastie
User offline. Last seen 3 years 22 weeks ago. Offline
Hi There,
Are you using P3 3.1, if so i have had this problem as well, try solution 2001122118299 on the Primavera knowledge base
Here’s the solution if you dont have access to the knowledgebase
1. Create a new folder on a Local Drive that has no spaces or symbols, has 8 characters or less, and is no more than 5 levels deep. For example, C:\PDFPort.
2. Go to Start, Control Panel, Printers and Faxes. Right-click on the icon for Acrobat Distiller and select Properties.
3. Select the Ports tab, then click the Add Port... button.
4. Select PDF Port and click on the New Port... button.
5. Select the new folder you created and click OK. Click X to close Printer Ports dialog.
6. Make sure the new PDFPort is selected
7. Click on the Advanced tab. Select "Spool print documents so program finishes printing faster" and "Start printing after last page is spooled" options.
8. Click Apply then click Close. You should be able to successfully create a PDF file using Distiller next time you launch P3.
Hope this helps
Ronald Winter
... Also make sure that you have installed Service Pack 3 with P3 Version 3.1. It cures many PDF problems. Good luck!
Hannes de Bruyne
User offline. Last seen 2 years 23 weeks ago. Offline
try settings in your PDF-Printer to put the quality of your PDF-File down to 300dpi
Hannes
