How to Filter the Lower Levels of a WBS alone ?
8 replies [Last post]
Pranab Kumar Deb
Dear All,
Can some body guide me filtering the lower levels of a WBS without selecting all the WBS separately ?
regards
deb
Pranab Kumar Deb
thanks frank it works perfectly well
regards
deb
Frank Borcherdt
User offline. Last seen 8 years 11 weeks ago. Offline
P3 ver 3.1 and works fine for me. Could not survive without it.
Filter should read WBS EQ ??.??.03.??.??.?? note that you should put ? in all positions of WBS that you have defined and want to select all values. Works on any field including activity ID.
Frank Borcherdt
Ahmed Syed
User offline. Last seen 9 years 25 weeks ago. Offline
Hi Frank Borcherdt
What version of Primavera you are on? As I tried it on ver 3.0 and it did not produce anything?
Frank Borcherdt
The ? can be used in filters as a wildcard ie. any value is selected, so ??.??.03.??.??.?? will pick up all activities with WBS level 3 value of 03.
HTH
Frank Borcherdt
Ahmed Syed
Hi Pranab Kumar
If you have structured your WBS effectively, you can ORGANISE the LAYOUT based on your WBS levels. What I suggest you is to hide all other levels except your intended WBS Level and run ORGANISE NOW.
Hopefully, this will help you.
Ashraf Jahangeer
User offline. Last seen 8 years 51 weeks ago. Offline
Now UAE, QATAR and Bahrain the weekend is changed to Friday Saturday. Kuwait will also catch-up.
Reg...Ashraf
Pranab Kumar Deb
Ya man i too think so and am a junior one only ,
but then full middle east is working on sat and sunday , and the concentration of planners is also high but dont know why there is no reply
regards
deb
Ashraf Jahangeer
Deb,
Apart from You, me and Ahamed hardly anybody is present to guide.
They are all having a nice week-end.
Ashraf
