Open the folder where you saved the file. Look for a file that ends with "LOG" (i.e if your file name is "SMKD" the file will be "SMKDLOG"). Delete this file and reopen your project.
The log records will no longer be present. You may decide to add additional log or simply close your project. A new "LOG" file will be created automatically in the folder where the previous "LOG" file was located.
Alternatively, a colleague just advised me that after exporting to a dbf file - insert a new column called Delete - then populate with the letter L - finally, import the data.
Much appreciated.
Paul
18 years 7 months
Member for18 years7 months
Submitted by Francisco José… on Tue, 2007-03-27 12:28
You can try through export/import tools. You can first export to a dbf file your logs, then open in excel and emptying them and finally import again. The result will be no log at your schedule.
22 years 1 monthRE: removing historical data from Log Record
If it does not works, please let me know.
Akin Adurosakin
Nigeria
19 yearsRE: removing historical data from Log Record
create a new project BLNK (blank).
then u should find a file BLNKLOG.p3
if ur project that u wnat to remover the relationship is ABCD, you can delete (or rename just to be safe) ABCDLOG.p3
Copy BLNKLOG.p3 as the new ABCDLOG.p3
That should work...
It worked for me when i remove all resources using same method for ????RES.p3
19 years 11 monthsRE: removing historical data from Log Record
Thank you, Paco
Much appreciated.
Paul
18 years 7 monthsRE: removing historical data from Log Record
Paco
