Filter on Target /Baseline Programme - Needs help
Shahab Ali
User offline. Last seen 13 years 14 weeks ago. Offline
I need help.
I have to plans one is target and other is current in P3 ver 3.1. I want to filter the activities in the current project of the target project within period range.
Have anyone some bright idea. I searched a lot, this facility is not available in this version. Am I right?
Shahab
Shahab Ali
Thanks! both guys
Now I remembered, I did same thing 2 years back as Alex said. I needed two weeks look ahead filter on target programme while opening current progamme. In my case Alex idea is the easiest one.
Thanks once again
Shahab
Prabin Kumar
User offline. Last seen 9 years 11 weeks ago. Offline
Alex,
Yes, your idea is quite good and its easy also.
For the global change with targeted dates as a condition I still wish to insist that its possible.
After opening ’Data item’ for writing a condition, select Target data, choose T1ES /T1EF/T2EF/T2EF....,whatever suits to the condition and run..
Am I wrong ?
I had tried this !
Prabin
Alex Wong
User offline. Last seen 11 years 42 weeks ago. Offline
Groups: TILOS
Probin
I dont think you can use global change with targeted dates as a condition(correct me if I am wrong)
My suggestion is
create a CDI call PF - PS (Normally it is already created)
export your target schedule ES EF
export your current schedule with PF & PS
Replace PF and PS with target ES and EF
Import back to your current schedule
from this date onward you can filter all your plan date (Target) and dont need to use global change
Good Luck
Alex
Prabin Kumar
I tried like this!
First I added a new activity code(say ’tar’) to the current project and then opened Global change, feeded the logic with Target early start/target early finish with respect to duration (if logic is true - add ’tar’ EQ ’F’ else ’blank’)
After running the global change, filtered the activity having ’tar = F’
thanks,
Prabin Kumar
Shahab Ali
I need help.
I have two (2) plans one is target and other is current in P3 ver 3.1. I want to filter the activities in the current project of the target project within period range.
Shahab
