How to Change WBS Sequence
Kelly Randolph
User offline. Last seen 18 years 16 weeks ago. Offline
I have imported a project from Primavera 5.0 into P3 and the WBS got out of sequence. How Can I restore to the original WBS order?
Kelly
Alex Wong
User offline. Last seen 11 years 48 weeks ago. Offline
Groups: TILOS
Kelly
ANother dump way of doing it is export the WBS number
Delete the items that is out of sequencey
Add back the WBS item to the correct location
and Import back the WBS assignment
HTH
Alex
Kelly Randolph
I guess I should have thought about it a little more but I should be able to create activity codes that mirror the WBS and then use the group/sort by function to get the order I want. Yes or NO?
Kelly
David Kelly
User offline. Last seen 2 years 30 weeks ago. Offline
OOPS, that was the way you do it when you move from P3 to P5. There is NO way to change the sequence of the P3 WBS, other than the ASCII collating sequence (e.g. alphabetical order)
David Kelly
Use the "indent/outdent" buttons on the extreme right of the WBS screen. Any WBS sorted output foillows the sequence of the WBS that you create in the WBS screen
