Detecting changes in the software
6 replies [Last post]
ayman eleish
User offline. Last seen 16 years 35 weeks ago. Offline
Is there a way to detect any changes happened in the project software in p3
thanks
Rolyn Jalea
User offline. Last seen 13 years 4 weeks ago. Offline
The problem is not all the time you will see the problem... not unless you use these softwares.
Philip Jonker
User offline. Last seen 16 years 30 weeks ago. Offline
My problem here s that you guys do not know your arses from your elbows, and if you were half decent planners would have seen the problems ahead of time instead of trying to use software to detect it for you
MK TSE
User offline. Last seen 5 years 4 weeks ago. Offline
Further to Gorden’s post, if you want to check what is included in each version upgrade or service pack release, information is available on Primavera KnowledgeBase.
MK TSE
Besides Claim Digger, another software name PrimaPlan Project Investigator can run the comparison.
Mario Sanvitale
User offline. Last seen 13 years 22 weeks ago. Offline
Alternatively use something like Claim Digger which is a low-cost Primavera-supplied add-in (embedded in primavera 5) to compare two iteration of the same project, or any two-project combinations.
Gordon Blair
User offline. Last seen 7 years 22 weeks ago. Offline
Ayman,
If you’re talking about upgrades, patches etc.. then you need to look in Help / About P3... any service packs will be detailed above the license agreement.
If you mean, are there any material changes to the Project itself, you need to create a baseline and either compare against Target1 columns or look up the Var. Columns.
HTH,
Gordon
