Planned % comp based on Late dates.
7 replies [Last post]
Muhammad Ali
User offline. Last seen 13 weeks 3 days ago. Offline
Friends!
I am monitoring progress based on “Duration”. I want to draw a set of S curves in X-cel (Early and Late) for the planned progress % comp based on duration.
To get early planned % comp > I use Automatic update (Control F9) run the progress on weekly basis (repeatedly). The program activities are run on all early dates and summarization based on duration gives me overall planned % comp.
Coming to the exact querry. . Is there any way to get planned Late % comp. Like any option which makes Automatic update to start all the activities on their late dates, so that I can have planned Late % comp. !!
Thanx
Muhammad Ali
Daya I agree with you. Thanx Eric for you tip!! It really worked . .
Dayanidhi Dhandapany
User offline. Last seen 3 years 35 weeks ago. Offline
Follow Erik’s advice; it would be easier to introduce a dummy resource to accomplish your task.
Erik Jonker
User offline. Last seen 5 years 30 weeks ago. Offline
Hi Muhammad,
The only way to do this would be to create a duration resource.
The easiest way would be to add a resource called time and set the budget quantity equal to the original duration.
You would then be able to do an s-curve.
Erik
Muhammad Ali
What I understand is that in Tools > Tabular or graphical reports, all reports are based on either cost or quantity.
Assume that my schedule is not cost or resource (Qty) loaded. I can not use any tabluar or graphical report!! My schedule contains only activities and I want to develop Early and Late S curves for the planned % comp.
My progress measurment will only be based on Tools > Options > Summarization > Duration.
May be I was unable to explain my querry properly.
Jaco Stadler
User offline. Last seen 18 years 6 weeks ago. Offline
The Easy Way is to export the summary the report I found the easiast is Tools / Tabluar Report / Tabular / RT1.
You modify this report (Or copy) Then you Export You Can Select Which Dates you want to export on this (Timescale)
Hope this help
Muhammad Ali
Well, as long as I am able to get the data (could be a column inside the P3 schedule) I can export it to Xcel. My objective is to get % late comp for each activity that can be summarized to an overall % comp. . . .
Jaco Stadler
Do you want to show the percentage in a Column on the schedule or on the S-Curve
