Import WBS from Excel
6 replies [Last post]
Paul Kleppert
User offline. Last seen 11 weeks 1 day ago. Offline
I have spent all day trying to understand why my WBS codes will not import from Excel proprerly. The report says "Blank level of WBS value detected, omit processing WBS part of import record". I have read/asked and knowone knows what is happening. Has anyone run into this problem before or know what is happening?
Paul
User offline. Last seen 14 weeks 12 hours ago. Offline
unless you use sdk you really cant import the structure only the assignments of the wbs codes to the individual activities.
If you are using anyhting later than verison 8.4 sdk wil not work
Please do not take me on, on this but it is always recommended that you put the first line manually in P6. Then do your input. It will also apply for import of resources as well.
Shree Abdullah
User offline. Last seen 4 years 32 weeks ago. Offline
i am unable to import wbs name into p6. it imports the wbs code activities and their ids but the name of wbs does not import. please help me out on this. thank you
MK TSE
User offline. Last seen 4 years 35 weeks ago. Offline
May I know the import WBS codes is to WBS dictionary or against each activities?
If WBS dictionary, please note the sequence of data, the spacing between characters and format of the code value.
If WBS against activities, please check the data format.
Luca Basile
User offline. Last seen 10 years 3 days ago. Offline
Groups: TILOS
Have You try the excel utility given in P3 CD-ROM, to import and export WBS structure of the projects?
It should not be affected if some level are "blanck" as look like from You post.
Is in the RA folder.
MK TSE
I think it is the sequence of data only. For example, import 1.3 before 1.3.1
