Microsoft Project conversion to P3 expectations
17 replies [Last post]
Alphons Bruns
User offline. Last seen 28 weeks 6 days ago. Offline
Dear PP people,
I would like to hear what kind of problems can occur when a planning is converted from MPP ->MPX -> to P3.
At the moment I am assigned to a firm that wants to put all the MP98 and MP2000 projects into P3 (and later maybe even into P3e) . How to convert I know, but what to expect from the results afterwards, and the work to be done to make the schedules trustfull working.
Suggestions and experience is very welcome on this subject.
Jorge Taguinod
User offline. Last seen 3 years 9 weeks ago. Offline
Durgesh,
1. Activity Durations: You may want to do a global change to divide all durations by 8 to convert from hourly durations to days. Or you may want to export Act ID and OD to excel, divide all ODs by 8, and import back into P3.
2. MS Project uses sub-activities to handle WBS. Primavera handles it differently. Since you’re moving to P3, you have to decide if you’re going to use Activity Coding and/or WBS. In any case, you may delete these topic activities from MSP. But you’ll have to create a project structure (Act Coding or WBS) to categorize your detailed activities.
This is what I meant by "doing some work" when converting from MSP to P3. It’s never a straighforward thing. One time I converted a small schedule from MSP to P3 and it took me a loooong time. I should have just done it in P3 from scratch instead of importing the schedule.
Goodluck.
Jorge
DURGESH NARAYAN M...
User offline. Last seen 13 years 17 weeks ago. Offline
hi all!
i just converted msp programme in to mpx to convert in p3,
the problem i am facing is that, earlier the duration of the activities were in days & now they have automatically converted in hours in mpx programme which i want to be in days.
2nd problem is thatwhn i am conVerting mpx programme in p3, the main task is coming as TOPIC & NOT AS HAMMOK.HOW TO CHANGE IT AS HAMMOK ACTIVITY TYPE.
IF ANY BODY CAN HELP IN THAT.
THNX & REGARDS
DURGESH MISHRA
SIEMENS-ETA CONSORTIUM
hi all!
2nd problem is thatwhn i am conerting mpx programme in p3, the main task is coming as TOPIC & NOT AS HAMMOK.
THNX & REGARDS
DURGESH MISHRA
Jorge Taguinod
Hi Alphons,
I didn’t know that. I use Batch File to do it. Thank you very much for the information. This should make things much easier.
Do you have the utility? Or can you tell me where to get it?
Jorge
Alphons Bruns
Hello Jorge, There are two import utilities, You make use of activity.xls. There is also dictionary.xls. With this tool you can indeed fill WBS and also Resources, Custom data items,Cost account information. Regards.
Jorge Taguinod
P3’s import facility can only be used to import activity data. You can’t use this facility to modify dictionaries (e.g. WBS structure). To do this, you will need to either input it manually in P3 or use Batch Processing.
Please refer to the documentation included in your software for this.
Note: It’s quite difficult to use WBS in P3, but it’s a breeze in MSP and P3e. This is the reason you’re having quite a hard time importing from MSP. The technical process is easy. It’s the rework that’s a pain. Consider using P3e.
Jorge
Paul Harris
User offline. Last seen 1 year 47 weeks ago. Offline
If I remember correctly P3 imports the WBS codes but not descriptions.
On the Primavera webs site Solution ID: 200252492644 supplies an Excel spreadsheet that can be used import the WBS codes and descriptions from MSP to P3.
You should be able to copy & paste the MSP WBS codes and summary task descriptions from MSP to the Excel Spreadsheet and then upload them to P3.
I have not specifically done this operation myself, but I often import Activity Code and Activity ID descriptions. If I had many WBS descriptions to upload, then this would be my approach.
Paul E Harris
www.eh.com.au
Alphons Bruns
You can fill a text field in MSP with the value of your WBS before you convert, and during conversion it can be made an Activity code. After that you can make the WBS equal to the Activity code you created with a global change.
Regards Alphons
THNX!!
I CONVERTED MSP IN TO P3 BUT THE PROBLEM NOW I AM FACING IS THAT P3 IS NOT TAKING MSP’S WBS DIRECTLY...
ANY SOLUTION ...PLZ.
THNANK YOU.
Bernard Ertl
User offline. Last seen 10 years 10 weeks ago. Offline
You can also try:
  • saving your MSP2000 project in MSP98 format and use MSP98 to generate an .MPX
  • the free MPX2000 applet from Sciforma Corp.
  • the (commercial) MPX Translator plug-in from Bluewater Project Management Services, LLC
I would suggest you contact Primavera directly with any licensing issues you may be experiencing with their software.
Bernard Ertl
InterPlan Systems Inc. - Project Management Software, Project Planning Software
Gussein Mamedov
User offline. Last seen 21 years 3 weeks ago. Offline
Dear All!
Please, kindly do me favor pls. I have tried all the instructions from you on this site. Thanks a lot. But since I tried to download this MPPtoMPX.exe from Primavera site, I can not register my P3 software, because its said my software is old in version, although my software is licensed officially ordered from Primavera itself by my company. Pls. kindly suggest how to solve the problem with convertion of MS Project 2000 files to P3. It is extremely important for me. May someone can forward me MPPtoMPX.exe utility already downloaded or there is another clue? My e-mail address guseinm@hotmail.com , corporate GMamedov@mqs.az
MK TSE
User offline. Last seen 4 years 37 weeks ago. Offline
I still suggest to re-do the import, then use some tools, like ClaimsDigger, PrimaPlan Project Investigator, etc to compare the 2 projects to list the differences. Then input those difference to the new one. I assume the difference are major your previous effort.
Clive Hibberd
User offline. Last seen 11 years 49 weeks ago. Offline
Topic activities in P3
Can anyone help? I have converted a MS Project 2000 programme to P3 but forgot to outdent all the activities before converting. The result is that now I keep getting Topic activities showing in P3 but can’t change them. If I create new tasks to replace the topic activities, and then delete the topic activities, P3 then changes the activity above from a task to a topic activity. Does anyone have a fix for this? Unfortunately I can’t re-do the import conversion because I have made many changes to the programme since.
Dave Rodwell
User offline. Last seen 20 years 31 weeks ago. Offline
I have tackled this conversion many times. It is not too bad to do, just make a cup of coffe, get comfortaable and allow sufficient time without interruption.
Jorge Taguinod
Uh oh!
This is going to be difficult especially of you want to be organized about it. One of your major problem would be activity coding, expecially if you need to convert multiple MSP schedules into a P3 project group.
I anticipate that you would have problems with most if not all the items under the Data Menu.
Too long to expound here.
Jorge
Paul Harris
There is a technical paper on my web site www.eh.com.au on converting P3/STW to and from MSP.
Paul E Harris
Director
