IF OR Fuction
7 replies [Last post]
Jithin Kambhikanam
User offline. Last seen 15 weeks 4 days ago. Offline
Hello All,
Need a help.
A formula to calulate the % duration complete based on IF OR function in excel
   Today = (D)28-May-22
ItemABDuration% Complete
Item 123-May-2228-May-226B=D,100%, A<D,B>A,(D-A+1)/(B-A+1)
Item 225-May-221-Jun-228
Jithin
User offline. Last seen 2 weeks 3 days ago. Offline
  • That activity time has elapsed or that some effort has been performed does not mean some volume of work has been done.
  • Using elapsed time to calculate progress of work is usually wrong even in the most simple of job as things rarely happen exactly as planned.
User offline. Last seen 16 weeks 6 days ago. Offline
glad I could help but my formula was correct based on what you had
you had  A<D
NOT A>D or B<D
was not excalty sure I but I did think your paramaters were incorrect to begin with but that was not what you asked
glad I could help wants exactly sure what you were trying to do.
Jithin Kambhikanam
Thanks Zoltan and Rodel,
That did help.
Rafel,
The weightage per activity is already given based on the resource requirement and its 7X7 job. So the duration consumed X by the weightage/ activity gives me the planned %.
Jithin
And what about non-work days such as vacations?
And what about multiple resouces with different calendars?
And what about shiftwork on same activity?
Unless activities are duration type such as concrete curing status and updating is a matter of volume of work. Statusing and updating activities that perform volume of work without considering volume of work is not a good idea.
User offline. Last seen 7 weeks 2 days ago. Offline
Zoltan furmula is correct with minor correction in case A > D or B < D or A=D.
=IF(B3<=$D$2,1,IF(A3<=$D$2,($D$2-A3+1)/(B3-A3+1),0))
Based on what you had here it is
Item Duration % CompleteToday = (D)
ABC28-May-22
23-May-2228-May-22100%
25-May-221-Jun-2250%
=IF(B3=$D$2,1,IF(A3<$D$2,($D$2-A3+1)/(B3-A3+1)))
