Changing OD w/out automatically changing activity % complete
John Rovir Ferna...
User offline. Last seen 10 years 50 weeks ago. Offline
Hi All,
Im making a revised schedule and this is one of my problem. I want to change the Original duration without changing automatically the Activity % complete. these activities already started and there are already progress on it.
I'll appreciate any help you give me. Thanks.
ECHEZONACHUKWU OB...
User offline. Last seen 6 years 24 weeks ago. Offline
Hi John,
It all depends on the kind of progress % complete type you are using, if it is duration % then it would be affected but if it is physical % complete then you can go ahead to input the correct original duration to reflect the obtainable duration. if you are using units %, it depends on the quantity of the job delivered for you to get the progress %.
I will advice you to always use physical % complete type so as to give accurate progress on the job.
Eche.
Muthukumaru Senth...
User offline. Last seen 12 years 39 weeks ago. Offline
Hi Jone;
Basically you are revising this duration due to inaccurate of the original planned duration, it means the started activity could not progress as you planned . Progress % and remaining durtion to be determined by you.
Senthuran
User offline. Last seen 25 weeks 3 days ago. Offline
Hi John
If you cannot just extend the end date of the uncompleted section then you may have to take off the progress - extend the durations and then add back the progress.
