Modify hyperlink path collectively
Raj Maurya
User offline. Last seen 3 years 20 weeks ago. Offline
Hey Guys
Can any one suggest a simple method to modify the hyperlink path collectively??
I have a excel file containing hyperlinks say more that 500, and I want to move that file in another drive suppose from X to X_N or if I renamed it then I need to update the path of all hyperlinks. Do any one have easy way of doing instead of modifying it one by one.
For e.g. old file lying in X:\A\H\M\aaa.xls
and new file X_n:\A\HH\M\aaa.xls
Rashid Iqbal
User offline. Last seen 17 years 33 weeks ago. Offline
Raj,
Try Edit Find Replace and i hope it should work. For example in Find Place the old Path i.e. X:\A\H\M\ and in replace place the new path and which would be X_n:\A\HH\M. Click to search in formulas and i believe then you are ready to go for ’Replace All’.
Raj Maurya
Hi Rashid,
It is not updated by itself.
Here old drive and its files shifted in to a new drive and path as I gave example. Since path of all hyperlinks the same(not changed automatically) after placing the file at new location. If I don’t edit them and click hyperlink then that link searchs according to its old path.
Rashid Iqbal
If i have got your question right, then just open the file and save it in the desired place, everything should be updated all by itself.
Rashid
