Suretrak - Weekdays and Weekend days Count
k.k. reddy
User offline. Last seen 22 years 7 weeks ago. Offline
I am creating a project schedule with SureTrak,
The following is the issue,
Any help will be appreciated. Thank you.
I want to count weekdays and weekends.
For one item, I put in Start_Date 01/28/03 and 62 days to complete.
End_Date is suppose to be 03/31/03, but SureTrak is giving me
End_Date as 04/23/2003. Is there any way I can count all days,
both weekdays and weekends, and put in End_Date as 03/31/03
on the screen, as calculated.
Ed van der Tak
User offline. Last seen 1 year 8 weeks ago. Offline
While checking your question in suretrack I found the following :
1) Check the exceptions option in the calendar, it could contain dates!
2) The global calendar has effect on using calendar no. 1. Make this global calendar "empty" ie 7days/week and define exceptions in the others 1,2,3,4 etc calendars. Only days applicable for ALL calendars should remain in the global calendar.
I hope this solves your problem.
Plan for the best,
Ed van der Tak
ARAM Planning Consultants
The Netherlands
k.k. reddy
Steven, No luck.
Even I created new calendar, with 7 days 8 hrs day week.
Steven Oliver
User offline. Last seen 12 years 18 weeks ago. Offline
Check your calender, if Sat/Sun are classed as non working, either change them to working days, or create a new calender with the working days you require.
Same goes for holiday days.
have fun
