Event Code: CNFFZ\-0464-A (Could not find \bin\java.exe)
I have currently been trying to import Microsoft Project XML Programmes into Primavera P6 Professional R16.2. Every Time i attempt to this, i get a EInOutError with the event code CNFF\-0464-A and the description 'Could not find file\bin\java.exe
Would anyone be able to assist with this and help me be able to import XML files to P6.
Any Help Would Be Much Appreciated,
Jordan
Z
yes make sure the path of the localtion of java in your system environment
David Kelly 👤 Member for 21 years 8 months
Jordan,
Importing MSP files is at the 'flakey' edge pf P6 capabilities. Sounds like you have a classic 'JAVA_HOME' issue, but the XML file may never import anyway, becuase half the time they don't.
Perhaps two stages:
If you email me the XML file, I can try and convert it, this will take me 10 minutes max, as I may have to open it in MSP to 'fix' it.
If it does convert, then it is worth the aggrevation of sorting your java issue.
[email protected]
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Nick Johnson-Pond
