P6 removes remaining labour units and costs when actualising finish.
8 replies [Last post]
Thomas Nicholson
User offline. Last seen 13 weeks 5 days ago. Offline
Hi all,
I'm just after some clarification rather than help for a change. it's something we've not noticed before and it could just be us but when we actualise the finish date of an activity has P6 always removed remaining costs and units automatically?  My planners and I are sure we've had to work on costs after doing this in the past.
I just want to be sure in case someone in our organisation has changed a setting I can't see offhand to make it do this all of a sudden.
Thom
User offline. Last seen 9 weeks 5 days ago. Offline
you can change it if you want to
Thomas Nicholson
Zoltan,
I knew there was a setting somewhere for it, thank you for that but I take your point about done is done.
cheers
Thom
Thomas Nicholson
Zoltan,
cheers
Thom
if you do not want to do this then turn the setting off
go to projects directory
then the calculations tab
on the right resource assignments
under when updaing Actual units or costs uncheck Recalculate Actual Units and costs whne duration % complete changes
Thomas Nicholson
Hi Zoltan,
I know I know, but it's one of those things I'm sure we've never seen our system do before.  Usually we've had to sort the remaining and costs ourselves.  Logically it makes sense, we've just got to sort the costs before pushing the button.
Thank you as always for being the voice of reason.
Thom
done is done why would you have any remaining unless you completed it in less time than planned ?
User offline. Last seen 7 weeks 12 hours ago. Offline
Hi Thomas,
That is correct. P6 will automatically removed remaining Cost and remaining Unit when actualised the finished date. If you have actualised the cost and units to less or greater than budgeted unit / cost then tick the actual finished date, therefore what ever remaining unit/ cost will be removed. The main reason is if the Activity is completed then no more remaining duration. It's self explanatory. If no more remaining duration, therefore no duration left to hold the remaining cost/ unit. You cannot assume 0 duration can hold cost or unit.
