Resource % Usage in P6
Eric Gonzalez
User offline. Last seen 4 years 22 weeks ago. Offline
How do I go about in assingning resources with a specific % usage within P6? Looking to mirrior the same function as in Microsoft projects resources. Anythings helps. Thanks.
create a resource and if you are assign it as 8 hours per day it will automatically multiply 8 times your duration so
5 days = 8*5 = 40 hours this is the default basically 1 man per task
export the resource and units (manhours) to excel and make your modifications there and then import back into p6.
Sterling Gallagher
User offline. Last seen 1 year 24 weeks ago. Offline
Hi Eric
The setting is in - User Preferences - Dates -  Units/Time format  - Change to (show as a percentage (50%)).
Then in the Activities screen when you go to the resources tab of the Details window, add the column "Remaining Units/Time".  This column will be shown as a % of the resource calendar assigned to the resource you add to the activity.
If you leave the Units/Time Format as "Show as units/duration (4h/d)", the Remaining Units/Time column will be represented as hours of the assigned resource calendar.  Just be aware when you have the setting in this configuration, the "Durations Format" of the "User Preferences - Time Units" tab will affect how the "Remaining Units/Time" is represented.  For example if you set the "Durations Format" to hour, the "Remaining Units/Time" will say 1/h wich is equivalent to 8h/d or 100% if the resource calendar is your standard 8 hour per day calendar.
If you set the "Durations Format" to "Day" the "Remaining Units/Time" will say 8/d wich is equivalent to 1/h or 100% if the resource calendar is your standard 8 hour per day calendar.
Hope this helps
