Percent Complete Changed when Baseline is inserted
Robin Reyes
User offline. Last seen 4 years 16 weeks ago. Offline
Groups: GPC Qatar
I am receiving an xer for the schedule update from the Contractor. The percent complete used for progress is the Cost Percent Complete. However, when I inserted the baseline into the schedule, the values on the Cost Percent Complete changes. When i removed the baseline, the Cost Percent Complete return to its original values. Does anyone knows the reason behind this? Thanks
User offline. Last seen 2 weeks 5 days ago. Offline
just ask here or in linkedin and we will set you strainght.
Johannes Vandenberg
Hello Zoltan
Thanks for this information. I recently moved to a new P6 database and forgot to change this default setting. Cost me hours to correct. Paul Harris also published this particular setting in the Admin.
Regards Johannes
goto
Admin
Admin Preferences
Earned Value Tab
Then at the bottom under earned Value Calculations
make sure that the selection is Budgeted Values with current dates NOT PLANNED DATES
