Detailed Resource allocation after Export and then Import
13 replies [Last post]
Jithin Kambhikanam
User offline. Last seen 8 weeks 5 days ago. Offline
Hello Everyone,
Need some help. Can we Export Activity to Excel and then populate the resorce in it and import it back to P6. And that too if the same activity has multiple resource like,
Activity - Foundation for Tank
Resource:
Steel Fixer - 40 Hrs
Carpenter - 16 Hrs
Mason - 16 Hrs
Labor - 112 Hrs
I would like to see in the imported Excel something like this so that it easy to load the resource,
Activity IDActivitySteel FixerCarpenterMasonLabor
A-1000Foundation for Tank401616112
Jithin
User offline. Last seen 3 weeks 2 days ago. Offline
assign the resources to the activities in p6 then export to excel then populate then import to p6
User offline. Last seen 26 weeks 6 days ago. Offline
Kirill,
Thank you, I look forward to seeing more about it.
Kirill PM
User offline. Last seen 4 years 41 weeks ago. Offline
Unfortunately there are no materials in English for now.
We are in the process of creating a new website, the English version will be ready in a month i think.
Kirill PM
Kirill,
Thats an interesting application - but seems to be only available for the Russian market? Is there any infromation availabel in English - other than a website auto-translation?
Kirill PM
I think you are looking for something like this:
https://youtu.be/6_KZYCOBl-k
Jithin Kambhikanam
Hi Kannan,
I stared doing that. Filter it by Activity ID then populate.
Ya that is one more Idea, let me see which would be faster and better.
Jithin
Jithin,
The XLS import/export work as the Database tables are written, to have one line per activity with all the resoures horiztonally would not be a flat data file.
You could develop some excel forumals using INDEX and VLOOKUP formulas to achieve what you're after.
Kannan CP
User offline. Last seen 19 weeks 3 days ago. Offline
Hi Jithin,
I believe that after the exporting, you can't change the basic structure of the excel file ( top-down to horizontal).
You can filter the act-ID and populate the resource units much faster in the excel file, and then you can import it.
BR
Kannan
Jithin Kambhikanam
Hi Santosh,
Ya did that and Yes it showing but in a Horizontal Way. Like if for 1 Activity if there is 10 Resource then the 10 Resource would be shown Vertically.
But before it is been exported under the Template, in the Subject Area you have to select Resource Assigment and add the related columnn
If the resource was shown Horizontally per Activty then the Resource loading would have been better.
Just manually populate one activity with the resources and units you want to include.
Then select FILE>EXPORT>XLS>RESOURCE ASSIGNMENTS and it will be easy to see how this is done
Then complete populating in Excel and select FILE>IMPORT>XLS and point to the same file exported above.
Jithin Kambhikanam
Hi David,
Thanks, could you guide me with an example like how the template would be in actual. I am in Oil and Gas same as you, so my current scenario for example there is a deliverable Design Basis for which all the Dicipline needs to give there input so that 1 Deliverable would have hours of Process, Mechanical, Piping, Electrical, Instrumentation, Civil. So I need to put hours of all of this dicipline into to this Delvierable as a separate resource.
I will be working on a Project in which there would be many engineering deliverable.
So could you help me out with an example
Jithin
David Kelly
User offline. Last seen 2 years 16 weeks ago. Offline
Jithin,
Yes you can export a template of resource assignments, and import them with new values BUT it cannot be done in the format you want.
It must be one row in the spreadsheet, one resource assignment:
A-1000  Steelfixer 40
A-1000 Carpenter 16
A-1000 Mason 16
etc.
