Activity Name in ALL CAPS
6 replies [Last post]
Jeff Waldrop
User offline. Last seen 1 year 49 weeks ago. Offline
Some won't like it, but I tend to like all Activitiy Names or Desciptions in ALL UPPER CASE simply because it is easier to see.  Is there a way to change the case quickly to all upper case? or Vice Versa.  Just curious....
Jeff
Jeff Waldrop
Thanks, Steve.   Will give this a try...
Jeff Waldrop
Thanks, Steven....
I appreciate the suggestion.  Will give it a try.
Jeff
Steven Auld
User offline. Last seen 24 weeks 21 hours ago. Offline
Managed to check & unfortunately this is not one of the string functions available in the global change, so would need to do it through excel.
Steven
User offline. Last seen 29 weeks 5 days ago. Offline
Steven has it correct but I woul like to add that adny new activites that you ADD to the schedule make them lower case or initial caps so that you know it a change order or ithat this activity ws not in the original basline schedule
Balaji Chandrasek...
User offline. Last seen 5 years 48 weeks ago. Offline
Hello Steve,
Could you please help me sharing the coding or parameter setting for Global change of all Caps or vice versa in P6.
Steven Auld
Jeff,
Easiest way I can think of is to export the tasks to excel, add a column at the end & use the =UPPER(A3) formula (where cell A3 is the first task description.
Copy this formula down for all rows, then re-select and copy this column, go to cell A3 then right click & paste values.
Re-select the calculated column then clear contents.
Re-import the excel version of the plan.
If you are working on a large schedule, make sure that you export the minimum amount of columns to speed up the export / import process.
You may be able to do this with a global change within Primavera, however not in front of my computer to test.
Hope this helps
Steven
