Print Activity Name and resource
6 replies [Last post]
Suresh Sankaranku...
User offline. Last seen 6 years 10 weeks ago. Offline
Can anyone suggest some easy way to see the each activity and the resource & budgeted units related to the activity.
Eg: Activity id Activity name
0010 Remove PSV
Resource Budgeted Units
Lagger 10 Hrs
Crane 2 hrs
Rigger 4 hrs
Same way i want to give a report of resource which is related to each activity for an Equipment. I tried many reports but is there any simple way ?
Thank you
Roger Booth
User offline. Last seen 5 years 43 weeks ago. Offline
I have just done a report to do exactly this. Quite easy to do using the report wizard. Just have a go, you can’t do any damage, you can always delete your new report and have another go. It gets easier each time you do it.
Dieter Wambach
User offline. Last seen 8 years 26 weeks ago. Offline
Hi Suresh
You are right. In that view you can find the project but not WBS. A workaround would be, to create an activity code "a_wbs" and assign it to the activities. Folowing this code you can filter.
This way I did it already in the past because in some of the reports you can’t filter or group according to WBS, but in most cases according to an activity code.
Dieter,
Yes, Assignments is the best but still in the filter i dont find the WBS or I am not able to put the filter liem " Activtity Name contains = " xyz" . There is only Activity name = Equal or not equal .
Brad Lord
User offline. Last seen 11 years 20 weeks ago. Offline
dieter
thought he was talking about P3.1,
durrrh!!!!
Dieter Wambach
Hi Suresh
A different way would be: you’ll change to the view "Assignment" and then group by activity.
If you want to create a report, select the group "Activity Resource&Role assignments.
Brad Lord
suresh
create a layout with the columns that you want
re
Act ID, Act Desc, ES, EF, BQ’etc
reorganise on resource, and show totals etc,
you can also create a filter to display only activities with resoruces assigned,
save the layout as cost or resource or whatever you want
hope that helps
