Activities in which WBS Level in any view
Pranab Kumar Deb
User offline. Last seen 3 years 27 weeks ago. Offline
All,
Is there a way of showing the WBS level in any view? Even a formulae in global change to show the WBS level that the activity is in would help.
Pranab
User offline. Last seen 29 weeks 2 days ago. Offline
Prenab,
I don't know of any in0built field in P6 that tells you that any particular activity is "level4" or "level7" of the WBS hierarchy.
If I was tasked with presenting this, I would generate an activity Number UDF field, an use Excel to generate a value that would be imported back into the schedule to present. But you need to do this each time new activities were generated or if the WBS structure was changed.
User offline. Last seen 5 days 18 hours ago. Offline
While other software can display WBS level as an activity field it looks like P6 cannot.Activity_WBS_leveljpg_Page1
Of course P6 know the level and indent activity names accordingly, therefore if using Excel this can be calculated.
https://doduykhuong.com/2018/04/01/primavera-p6-export-to-excel-how-to-identify-wbs-level-for-activity/
User offline. Last seen 5 weeks 5 days ago. Offline
do you mean in the gantt area where the bars are ?
if so in the gannt area rigth click bars
look for current bar labels and highlight it
then click on the bars label tab
on the bottom click Add
then select the position that you want it on the bar
under label select wbs path
or go to current bar
click on bar labels
if you are putting it under the bar make sure that the row hight is large enough to see it
if you are looking to band the wbs in the gantt area that is not possible
Pranab Kumar Deb
Hi Santosh,
I meant as a number, in the activities view have against each activity a number showing what WBS level the activity is in.
thanks
Pranab
Try these:
1) Iin Group and Sort Options - for the WBS grouping you are using, tick the box to "Show ID/Code"
2) In Columns, show the "WBS Path" column
