Error when updating Remaining Units / Time
6 replies [Last post]
Bellota Castaneda
User offline. Last seen 1 year 12 weeks ago. Offline
Hello,
I'm trying to update the Remaining Units/Time in the Resource Activities in my schedule. I have done an export, update the file and when I import I get the following message:
Error: Cannot assign the same Resource: RSRC: xxx to TASK ActivityID: xxx, Project: xxx more than once
However, I do not want to add the same resource twice, I just want to update the Remaining Units/Time (h/d) column on the already existing Resource.
Any ideas??
-B
User offline. Last seen 22 weeks 2 days ago. Offline
Rajender Koilkonda
Start a new question this thread has to do with remaining units of time you question does not.So please do not hijack someone elses thread.
Rajender Koilkonda
User offline. Last seen 5 years 45 weeks ago. Offline
Hi guys,
Need some advise on how to resolve the below issue. My current user profile is a superuser. We have recently migrated from P6 ver 8.4 to ver 18. We use the export / import option for updating the progress due to the L5 breakdown of activities as manual updating takes ages.
Excel Import log started : 24-May-19INFO: Importing Global Data...INFO: Importing Project Data...INFO: Importing: WARNING: TASKRSRC: Failed to resolve foreign key for field Role ID with value RIGS. Field cleared.  "followed by the message below" ERROR: Cannot assign the same Resource: RSRC: DWN-TRD-RIGS to TASK ActivityID: T2-CR-STR-3830, Project: C1587399-45 - LIVE more than once.  Any assistance in this regard would be greatly appreciated. Kind Regards, Raj
Bellota Castaneda
Hei,
Thanks! I tried to export/import without changes as you mentioned but I get the same error, changes or no changes it just "thinks" I want to add a resource. This is driving me nuts. Any other ideas?
-B
the only thing that I can think of is that since you are chaning remaining units/time that it thinks that it is a nre resource. For a test try not changing it meaning export ti then try to re-import it leaving the remaining units/time the same. This will or will not verify my theory.
Bellota Castaneda
Hi, thanks for the reply.
I was already only importing the Resource Assignment, so I tried using the global change to update the "Claculate costs from units" field but nothing :/
I use export/import to update many fields and never get a problem, I wonder why Primavera "thinks" I want to add an extra resource...
Any other ideas??
-B
1. FOR THE RESOURCE manke sure that calculate cost from units is set to NO if it not then run a glocal chnage and chage it from yes to NO.
2. when you import the excel back in only selct resource ASSIGNMENTS during the import process NOT the resource.
