How to keep activity code when I copy project to other EPS
Nguyen To Tan
User offline. Last seen 10 years 8 weeks ago. Offline
Dear experts,
For example, I have a project(A) inside EPS (1). The project (A) has some activities which I added activity code (Area A, Area B...). But when I copy project (A) to other EPS (2), i lost all activity code which I added in activity. When I copied project, I ticked on all option of primavera requirement. I also used 2 way for copying ( 1.directly copy project/2.I made project (B) inside EPS(2) open 2 projects (A) &(B), in WBS window of (A) I copied them to (B) ) but I still lost activity code with activity in project (B). Could you help me? Thank you
User offline. Last seen 2 weeks 4 days ago. Offline
the codes you are showing are global so they reside with the database not the project so they are already there. So I am not sure of what your problem is now
Nguyen To Tan
Thank for your suggestion. But I think I already did same your way. I will show you something more clearly as below. And Could you explain more clearly?
Copy Project Pic
2466
Activity Code I used Pic
2468
actrivity codes come with the project unless 1 you do not have the rigths to export them and or 2 the person you gave the the xer to does not have rights to import them and 3 you can choose what and how you import codes. maybe your default setting is set to do not import codes
you can modify what and how you want to import infromation
during the importing process select modify and then choose to insert new activity codes
to see detailed instructions see my link
http://pmsite.com/forums/viewthread/3196/
User offline. Last seen 32 weeks 5 days ago. Offline
I suggests to use the Project Activity Code instead of Global.
