Determine Over Allocated Resource in Primavera P6
Galav Dani
User offline. Last seen 7 years 2 weeks ago. Offline
Hiii All...
Please someone suggest how to filter out all activities which having over allocation of resources for any proejct in Primavera P6?
please reply everybody.
User offline. Last seen 16 weeks 1 day ago. Offline
Johannes
He already knows the resource that is over loaded the question was how to find the activities that are comtribiting to the overloading.
as your jpg shows you can select view show on bottom resource usage profile and see which activities are in the time frame which is contributing to the overallocation
then you can assign a code to these activities then you can filter them out.
Johannes Vandenberg
User offline. Last seen 1 year 6 days ago. Offline
Hi Galav
You can identify the overloaded activities by filtering on the resource that is overloaded. You could add more resources, work additional hours or level the resources. Use the link below to see an example.
http://www.mediafire.com/view/8keket7ax8avd1w/Overallocated_resoursec.JPG
Regards Johannes
User offline. Last seen 4 days 21 hours ago. Offline
Deleted by Rafael Davila as to avoid annoying requests to revive this discussion as it is older tha 3 years.
So old no longer Photobucket pictures aer available.
you can identify which activities contribute to the overallocation of the resource.
just look at the timeframe of the activities during the period of overallocation.
You can select view show on bottom resource usage profile and see whihc activities are in the time frame which is inducated as being overallocated.
then you can assign a code to these activities.
