Ms project - Actual cost column
6 replies [Last post]
Bala Murugan
User offline. Last seen 1 year 9 weeks ago. Offline
Hi all planners,
I am using ms project-2007 for my scheduling works. I have created a schedule with work resource,cost resource and did save baseline. Now i want to change the values in actual cost column of cost resource based on the site progress but when i tried to do so, i got a problem. When i increase the value of actual cost more than that of baseline cost , the duration of the particular activity is also changing.
I increased the actual cost because of more wastage of materials in the particular activity. I didn't spend more manpower or duration.
Is there a way to enter the actual cost without disturbing the duration of the activity?
What am i missing?
Thanks in advance.
Ram
Bala Murugan
Evgeny,
              Yes, you are right. Thanks for your help...
Bala
Evgeny Z.
User offline. Last seen 1 year 25 weeks ago. Offline
Bala,
I do not have project 2007, but I could not reproduce the behavior, described by you with MS Project 2010. The behavior I observed is as follows:
  • It is not possible to change actual cost until activity is 100% complete. The actual cost in this case is calculated by the formula Actual Cost=Activity Cost*%complete
  • After activity is 100% complete, one can change actual cost and it does not change activity duration
Regards.
Evgeny
Bala Murugan
Hi kumar,
             The task is fixed work and effort driven. I have assigend work resource and cost resource. I didnt assign material resource. I entered the material value as a cost resource for the activity.
Thanks in advance,
Bala
Bala Murugan
Hi kumar,
Thanks in advance,
Bala
Kumar Baiju
User offline. Last seen 10 years 50 weeks ago. Offline
Hi bala
 can you say what is the task type. Is it Fixed duration, fixed unit or Fixed work. another thing you have have to check that the activity is effort driven or not. Have you enter material resource.
Regards\\
Kumar Baiju
Hi bala
Regards\\
