Give Column Showing Original No. of Days Allocated
IT Student
User offline. Last seen 21 years 30 weeks ago. Offline
When you set a baseline for a task & then insert a Tracking GANTT, the "Duration" column updates to reflect the actual no. of
days taken. I need to have a column which shows the initially allocated no. of days. How can I do that?
TIA,
IT Student.
Will Russell
User offline. Last seen 12 years 16 weeks ago. Offline
If you have set a baseline then the information you want is in the Baseline Duration column. Just insert that column into the Tracking Gantt view.
You really should go on an introductory course!!
Will
