Regarding Actual Qty in Activity Column
Kannan KG
User offline. Last seen 16 years 32 weeks ago. Offline
I want to use the Actual qty and qty completed in Activity column. I created actual qty and completed qty as custom data item.
And i added qty as Resources and assign qty in the resources, along with the some other resources also, but when i run gloabl change i am not able to select the single resource budgeted qty, it takes all the resources and the last resources buggeted qty is comming as a result.
how i can select single resources value in gloable change,
or any other method to show the actual and completed qty in Activity column.
Thanks in advance,
Kannan
Jackie Gilliland
User offline. Last seen 15 years 13 weeks ago. Offline
Hi Kannan
I did a quick check, on my first step below, you could actually load your first column by using a global change rather than to have to load it manually.
Good luck
Jackie Gilliland
Jackie Gilliland
Hi Kannan
I can quickly think of a solution to your problem but this is a pretty roundabout way, but should work.
create 3 data code fields.
In the first you will need to manually ad your actual quantity of the resource you would like to measure.
leave other 2 blank.
Now create a global change report with.
If: Leave blank
Then:Col 2 = Col 1 * pct
this will give you a value unfortunatly not divided by 100
Create a 2nd global change
If: Leave blank
Then:Col 3 = Col 2 / 100
This is quite an exercise for what you are looking for, so it depends on how seriously you need to do this. There may be shorter alternatives but this is off the top of my head.
good luck
Jackie Gilliland
Razi Khan
User offline. Last seen 9 years 1 day ago. Offline
Hi Kannan,
Can you elabroate little more with example ?
Razi Khan
MUHAMMAD IQBAL
User offline. Last seen 7 years 50 weeks ago. Offline
use logic in globle change and run
have fun
