Creating S-Curves in MS Project 2010
11 replies [Last post]
Ronald St.Hilaire
User offline. Last seen 13 years 6 days ago. Offline
Hi I have recently upgraded to MS Project 2010 and the Analyse Time Scale Data tab doesn't exist. Is there another way to create S-Curves on Project % Complete Planned vs Actual
Adolfo Caccialanza
User offline. Last seen 6 years 16 weeks ago. Offline
The best solution for Progress Curves Early & late is at this site:
http://www.cla-it.eu/TMSDetails-general.html
Chris Rymer
User offline. Last seen 4 years 2 days ago. Offline
With Project Tracker you can create S curves directly from Microsoft Project without the need to export the data to a spreadsheet. If you have the XML file you don't even have to have MSP on your machine. It can create the curve from the durations of the activities in your project plan, you do not need resource or cost allocations. For more information and a free trial, go to ww.willmer.co.uk.
Ronald St.Hilaire
Alexandre/ Donald,
Would it be possible for me to get your individual e-mail addresses?
Ronald.
Ronald St.Hilaire
Alexandre/ Donald,
Ronald.
Donald Harrold
User offline. Last seen 13 years 2 weeks ago. Offline
Right click on the table and you will be able to change the view to manhours
Ronald St.Hilaire
Donald
I don't understand if I'm in Task Usage the only thing I'm seeing is a Cash Flow Report.
Donald Harrold
The easiest and most flexible way to generate S-Curves is to copy and paste time phased data from the task usage table in to Excel. You will need to format man-hour data to remove the "h" so that Excel interprets the data correctly as numbers.
Ronald St.Hilaire
Hi Alexandre,
Thanks for the response. I went into the area put I'm stumped and I was wondering if you could give me some more help
  1. I hit the edit template button
  2. Selected Task % Comp
  3. This where I'm stumped, a prompt came back telling me to select a cost and I could go no further.
Can you guide me from here please? The help would be greatly appreciated.
Ronald
