Default calendar changed but made no impact
Lan Wei
User offline. Last seen 13 years 51 weeks ago. Offline
Dear fellow professionals,
I'm havign to use ms project 2003 to plan for a very small job, but with resource and number of hours (in work).
The actual working hours for all resources are 8-12, 13-16:30, so 7.5 hours per day and 37.5 hours per week. Straight forward. I therefore set this as default in the calendar, but when I go to the calendar itself the defalut for each day is still 8 hours, but when I check in Tools-Options-Calendar the default is as I set it to be. If I open "Change Working Time" all the default working days are still showing 8 hours per day, but when I click on options it shows my setting!
The result of this is that the software assumes there is 8 hours in a day, so 37.5 hours of work takes 4 and half days.
Can someone plase help?
thanks a lot
wei
Mufiz Sayed
User offline. Last seen 3 years 9 weeks ago. Offline
did your assign respective calender to activites & resources
