Default start-up loaded programme - change?
Dean Pearcy 👤 Member for 20 years 2 months
Dean,
First, you post it on a wrong forum. P6 users can look at your problem if it was posted on the correct forum.
Second, are you using a network or server base Database? By default P6 use the last save by the last user close the program. If the database running on the network sometime it will save last open project but depends on the network speed and other program running on the background like auto save or auto synchronization of your server and local drive (i.e. my documents which normally sit on network drive so when you logon to different machine still accessible) it affects the behavior of P6 and use users last save recognized on local drive which may not your current last use.
The fix is change the default start up to Projects instead of Activities under Edit-> User Preferences-> Application tab-> Start Up Windows
Haque Nawaz
EViLL1
Dimitrios Theocharidis
MichaelFuelsC
anwar zeb
olva seselima
Muhammd Muneer
sairam
MARAT BILYALOV
RichTea66
