NA for no value
Se de Leon
User offline. Last seen 4 years 11 weeks ago. Offline
MSProject shows an NA values for null or zero values. Does anyone know how to eliminate this.
Paul Harris
User offline. Last seen 12 weeks 3 days ago. Offline
Sigfredo Rex de leon
If the values change all the time then the option of making the text white may not be so convenient.
You may be able to use a Custom data item and a logical formula to put only the values you require in the new column.
Look under Tools, Customize, Fields, select a field from the drop down list and click on Formula button to see the calculation options.
Try looking under
Paul E Harris
www.eh.com.au
Raj Maurya
User offline. Last seen 4 years 17 weeks ago. Offline
Just change the color of font as background then it will not appear.
Tomasz Wiatr
User offline. Last seen 3 years 36 weeks ago. Offline
Dear Sigfredo,
It must be help for User but it is not help :-( It is Microsoft. You may axcept it or not :-) In my oppinion we have no solution here ...
Tom :-) fanatic of most customisable Pertmaster :-)
