Production Rates
C
Chris Oggham 👤 Member for 22 years 2 months
Note for PP Admin.
Just over three hours from getting an explanation of the problem to getting it fixed! I’m impressed!
Chris Oggham
F
Forum Guest 👤 Member for 17 years 5 months
Hello. I think we have fixed the production rates script error.
Let us know if it is still not OK for you.
PP Admin
F
Hello,
We can’t re-create the error. Can someone explain the issue for us. Sorry !!
Thanks.
deys nassah 👤 Member for 20 years 1 month
I forgot to mentione, I tried login suggestion - didn’t work for me!!
Waiting in anticipation...
Rgds
Deys
May be we are not filling in all the fields correctly!? I would like to requestthe PP moderators to give us an example of how to fill in the fields!!
Rgds
Deys
F
Hi there,
Appologies. We thought this issue had been fixed. I will chase the tech team today to see where we are, and why it has not been resolved.
I will report back shortly.
Thanks PP Admin
S
Se de Leon 👤 Member for 25 years 2 months
Hi guys,
Moderators correct me if I’m wrong. In order to access the productivity rates, 1 member should have at least recommended 2 additional members. Perhaps this could be the problem.
Se
C
Don’t know what else to suggest, except to send a private mail with the error message to PP Admin.
Chris Oggham
J
Julie Scully 👤 Member for 20 years 8 months
Logging in makes no difference, I’m always logged in when viewing the site, but as soon as I try to view a particular production rate I get the dreaded error.
Julie
C
Hi Anees,
You don’t have to logoff first, simply click on the Login / Join text on the navigation menu, and login as you would do normally. I’ve found that if I access Planning Planet through the link in a Post Notification, it doesn’t always log me in automatically. If I’m not logged in, I can’t access the Production Rates information.
Chris Oggham
C
Hi Guys,
I had an error message similar to the one described. I found that if I logged in again I could access the Prod-Rates Information.
Might be worth a try.
Chris Oggham
Richard Gush 👤 Member for 20 years 1 month
Hi Ronald,
I have the same error message...
Microsoft OLE DB Provider for ODBC Drivers error ’80040e31’
[MySQL][ODBC 3.51 Driver][mysqld-5.0.18-nt]Out of range value adjusted for column ’CSO’ at row 1
/output_results.asp, line 177
By the looks of thing’s it may not be working for people that are positions outside of the United States. That may be why you can’t see the error?
Richard Gush
Aneesuddin Zubair Mohammed 👤 Member for 22 years 8 months
Hi Chris,
I could not find the log out or sign off anywhere on this website. Correct me if I understood wrong, you mean to log-off and relog.
Anees
Hi Ronald,
Its the same error message...
deys
Maybe the moderators or site administartors can help with this, I am also not able to access the productivity rates!!!
Rgds
Dyes
Featured Partner
Zainab El-Beialy
Kamlesh Parmessur
MR JUDE C ANYAEGBU
GeoVe
Ashkan Mohammadi
Jeroen De Bauw
Senior Planning Engineer
Kristian Mcwilliams
dagogo dan - jumbo
