Float and dates don't nake sense
Catherine Groves
User offline. Last seen 4 years 21 weeks ago. Offline
 I have a schedule with a must finish by date of 6/24/21. The early finish for the project is 6/29/21, so about 5 days behind schedule. But it is showing -170 days of total float. I am not sure where this is computing from. The imposed finish is 6/24/2021 in properties. I have never had this happen before. Is there something I should at?
All my other projects are showing correct float. It is only this one.
Stephen Devaux
User offline. Last seen 4 weeks 2 days ago. Offline
Hi, Catherine. The good news is that if you need to compress your schedule by 5D, in Asta Powerproject you are using one of the very few software packages (along, notably, with Spider Project) that does the CPM computation of critical path drag that facilitates that process.
Steve the Bajan
Catherine Groves
Thanks Ben. Will do.
Ben Taunt
Hi Catherine,
Can you email your .pp file to support@elecosoft.com and mention the problem, and then we can see what is causing this.
Ben @ Powerproject
