How Do I Force Logout Admin if I don't have access to the Admin account?
John Mol
User offline. Last seen 8 years 28 weeks ago. Offline
I'm the P6 admin.  When I attempt to login as admin, Primavera tells me that admin is currently logged in.  It's been this way for a couple of days.  I've rebooted a couple of times since this has happend.  How can I force logout the admin acount if I can't access the admin account to force the logout?  Clear as mud?
Thanks!
John Mol
Thank you Zoltan!  We will give this a try.
User offline. Last seen 1 week 3 days ago. Offline
is you are using SQL then
you will have to log into the database execute a querie
select session_id from USESSION where delete_session_id is NULL and user_id = (select user_id from users where user_name = '<Enter User Name>');
If you run it and you get 1 as a result then
For all variables in the scripts below you are required to replace the variable (indicated by the <> symbols) with an actual variable. The greater than and less than signs should not be present in after the variables are populated.
Example:
<Enter User Name> becomes JohnDoe
<Session Id> becomes 1234
1.  Query the USESSION table for the users 'session_id':
select session_id from USESSION where delete_session_id is NULL and user_id = (select user_id from users where user_name = '<Enter User Name>');2.  Delete the users records in the table UPKLIST (Does not apply for SQL Lite):
Delete from UPKLIST where session_id = <session_id>;3.  Delete the users records in the table PROJSHAR:
Delete from PROJSHAR where session_id = <session_id>;4.  Delete the users records in the table USESSION:
Delete from USESSION where session_id = <session_id>;
