User defined columns
Chris Wilson
User offline. Last seen 2 years 5 weeks ago. Offline
Does anyone know if its possible to create user defined columns that you can populate from drop down lists?
looking to create  a columns where I can have units such as kg, tonne, m , m2 etc
Chris
Ben Taunt
User offline. Last seen 1 year 31 weeks ago. Offline
Hi Chris,
You could do this simply using Code Libraries.  Create a Code Library for your units, and then set that as a single select option.  Add the Code Library as a column and a drop down with your options will appear...
Also means you can then easily filter and sort etc.
Ben @ Powerproject
