Formula inserting in User Define Column In PRIMAVERA
K
Kumar Baiju 👤 Member for 15 years 5 months
Can we insert the formula in user defined colum in PRIMAVERA V 6.0. If Yes please guide how can we do that??
Regards\
KBJ
K
kumar s 👤 Member for 16 years 5 months
Dear
i think that you want to extend the start date by 15 days.
so for this first creatw the user defined field (slect the start date option) in the data type .
then use the follwoing global change parameter
if
all the actitivities or if you want to do it for certain no of activities then filter it before in the activity window before going for the global change.
then
select the user define date      =          start       (+)       15
you  will see the dates changed accordingly..
cheers
K
Thanks Kumar
I want to enter the date for which formula is as = Start date +15d.
how can i do this
Regards\\
K
Dear Baiju,
you can use the user defined field for entering the formula related data.
first create the user defined field and then go to the global change option.
there you can set the formulae and commit the changes.
the required values will appear accordingly in the coulums.
btw which type of formulae you were trying to display...
if required i can help in that..
cheers
Featured Partner
Kristian Mcwilliams
dagogo dan - jumbo
xerxes
edwin
jhalluk69
wilmoahyi
Peter Holroyd
Robert Guers
Our Partners
