Show Hammock allocation in a column at task level?
Hello,
I have a project on Asta that uses hammock tasks to summarise packages of work. I've been searching for a way to add a column that shows what hammock a task is assigned to; does anybody know if this is possible?
Any feedback would be greatly appreciated.
Rich
C
Charlotte Underhill 👤 Member for 10 years
Hi Richard,
You can use the parent name colun which is found under the identification category.
Hope this helps :)
M
Hi Richard.
Just change the code of the new task.
Mike T.
Richard Mann 👤 Member for 10 years 2 months
Thanks Mike, the only problem I have with that method is if I copy a task and it copies the code to the new task even though it's not allocated to the hammock of the original task. I wasn't sure if there was any other way of showing that the new task is not allocated to a hammock without doing it manually.
M
Hi Richard
Assign a code to each task and then assign the same code to the hammock.
Mike T.
Doron El
Erim INANC
gorilpk
Ricky
pinoyplanner
Siddharth Ranadive
Aidar Kurmantayev
Dave Morgan
blake333_
