Show Completed Task as Critical
6 replies [Last post]
Daniel Stoker
User offline. Last seen 5 years 17 weeks ago. Offline
Hello,
I'm looking to analyse the critical path of a part-completed programme for a project, however, tasks that are 100% complete or have been progressed do not show up as critical.
Is there any way of showing progressed items as critical without having to remove the existing progress from each task?
Dan Stoker
Daniel Stoker
Thanks Trevor,
The contradictory critical path of the as built is essentially what I was looking for.
Dan
Daniel Stoker
Thank you Abbas,
That is a good way to visually demonstrate.
Dan
Trevor Rabey
User offline. Last seen 2 years 24 weeks ago. Offline
Daniel, the answer is "no" and the reason is the definition of "critical". The entire concept of the critical path method is only applicable to tasks which are planned/scheduled in the future. Once a task has an actual start date and an actual finish date, which of course must be in the past, then it's earliest and latest start and finish dates no longer exist, or rather, they must be the same as actual start date and actual finish date. I suspect that you are trying to find something called an "as built critical path", which is just a contradiction in terms. Any help?
Abbas Shakourifar
User offline. Last seen 2 years 36 weeks ago. Offline
Hi Daniel,
An actual activity cannot be critical by definition. However, there are different ways to "Show" something critical.
If by showing you mean color "Red" follow these steps:
- Make a user-defined code and select the activities which you like to show as critical.
- On the Bar format table, Find the "Actual" Bar format, change your filter and make sure the coded activities are not included.
- on the Bar format table, add a new one, use your code to filter the activities which you need to shown as critical and format them as"Red".
I hope it helps.
Abbas
Daniel Stoker
Thanks Mike,
I had thought as much.
Dan Stoker
User offline. Last seen 23 weeks 4 days ago. Offline
Hi Daniel
No
