ASTA File locked when trying to save
Yasine Ali
User offline. Last seen 5 years 3 days ago. Offline
Hi everyone,
When trying to save an ASTA file, on the bottom right corner it says something along the lines of "Warning: file could not be saved due to being locked"
Anyone have any ideas on how to unlock it? so the changes on the programme can be saved.
Yasine Ali
Barbara, thank you for you're response!
It was exactly what you said it was, the view was "Locked" in the properties tab.
Barbara McAslan
User offline. Last seen 6 years 50 weeks ago. Offline
If you are using the barchart that has been set up as a 'View', you may have locked the 'View Settings' which is found under the View Properties.
B
