Viewing Filters With Project Viewer?
Chris Tracey
User offline. Last seen 11 years 39 weeks ago. Offline
Is there a way to view code library filters in asta project viewer?
Ive set a load up but cant see where to find them in project viewers view menu.
Any help much appriciated.
Ta.
User offline. Last seen 23 weeks 5 days ago. Offline
Hi Chris
Once you have set up a filter in v10 it is normally set up and saved in the list.
If it is not visible then it may be under "more filters" where you can tick the "show on menu" box.
You can also save your filter uinder the main "View" menu in the drop down View > Properties > Save as route.
